pinknuggit
- 530
- 1
- Oct 15, 2003
joplin,
Missouri
i bought this 1990 talon tsi fwd from a friend, and it does not run. It will crank over but not start.. symptoms are:
-No spark from the plugs and the fuel pump does not turn on
Everything works fine on the car, it's just that it won't start..
Also, it's got 210k miles on it.. is there anything i need to look at as far as "common trouble spots"?? any sensors that need to be replaced?
Also, there are no CEL codes, and when we hook the code reader up to the ecu, it will say "response Timed out" and not give any codes..
i've narrowed it down to most likely the ECU being bad.. is there a way i can test everything out to see what's the problem?
) To answer your question about the fuel pump, its located in the gas tank. You need to pull the carpet in the rear up and take out the spare. On the left of the car you will see where it goes in. Lastly, your CAS is all part of the spark process. If it is bad your car will not turn over (I had the same problem), although, there are 2 other parts that go along with the spark to, the Transistor pack, and Coil pack, but check the cas first.
