cam angle sensor question
bigjangin
458
Sep 1, 2003
Seattle, Washington
Got a few problems fixed, got a few left. There seems to be some trouble with the cam angle sensor. Every once in a while, the car will start and die after a few seconds and throw a cel for the cam sensor. However, it is starts up ok most of the time. Is it possible for the CAS to be partially bad, or does this sound more like a bad electrical connection somewhere in the wiring for the cas?
Replace the CAS. That SHOULD solve your problem. I've read about this happening to a few other people, as well. In relation to the car running for a few seconds than dying on a CAS CEL.
Someone hit me repeatedly upside the head with a baseball bat if I'm wrong.
