Someone out there has got to be able to help us with our boost creep!?!?
adam355
315
Aug 26, 2003
Urban, Wisconsin
Its just really really bugging me that I don't know what to do about it and when I made a post about it I never got a real answer. The sad thing is I noticed a few other posters the past few days that had the same problem and they didn't seem to get a real answer either. Heres 4 different members with the problem. My post is on top. Isn't there anyone on here that can help us?
http://www.dsmtuners.com/forums/showthread.php?s=&threadid=79136
http://www.dsmtuners.com/forums/showthread.php?s=&threadid=79801
http://www.dsmtuners.com/forums/showthread.php?s=&threadid=80006
http://www.dsmtuners.com/forums/showthread.php?s=&threadid=80072
"Just a thought. Do you have an adjustable acuator arm if so it might be too tight holding the wastegate shut to long."
I don't think it's adjustable. It's the actuator that is on the big16g. When I pressurized the lines with an air compressor it didn't take much to get the arm to move.
1. Install a 34 or 38mm flapper
2. Port the hell out of the WG passage (possibly remove the divider)
3. SEARCH
Boost creep questions are quite common, and I recall threads that even included pictures of what to remove.
If none of this helps, install a cat if you took yours off, or go external.
3. SEARCH
Lando pretty much gave you every option there is to eliminate da creep.
But in my opinion just Gate da planet.
