BlackViper
- 376
- Sep 3, 2002
Goose Creek,
South Carolina
Now that my car has been running for a little under a month it decided to kill itself once again. Now the problem is with the spark. Brand new mitsu sparks and plug wires from the Mitsu dealer. Been using them for about a month. RPM's are never steady at any speed not even with cruise.
Noticed the car would surge a little while I was driving on the freeway with cruise on. There wasn't an error code so I thought it wasn't a big problem. Got a code. 0300 which is random/multiple misfires. Took out the spark plugs to see if they were dirty. I wanted to check them so if they were running rich I could tell thats why they weren't firing. They look fine. After I put them back in I can't even get up to 10mph the car is vibrating back and forth from misfires so bad.
I got an error code like a week before with something about the exhaust recirculation wasn't right. Car was working fine at that point so I thought it was just some garbage code.
Car used to idle at 2000 in park, now its ok but in reverse or 1-4th the idle is down to 500 or less. Almost to the point of stalling.
Checked all my intake lines, they looked fine. Nothing that obvious wrong with the intake at least.
I think I'm going to try checking on the egr to fix the older code about the exhaust recirculation.
If that doesn't work I guess I'm shit out of luck once again.
BlackViper
BlackViper
I brought it to a friend who works at a smog place and it red lighted as soon as he steped on the gas hehe. So I guess I have to take off the plate when I'm ready to smog it. I made a blockoff using thick bendable sheetmetal from home-depot. Cheap yet effective. Hope that helps.
