Rear wheel bearing AWD....help!
A. Van
346
Jul 1, 2002
My passengerside rear wheel bearing is going out. I bought new bearings but it doesn't seem right. I was expecting a whole hub. All I got was the bearings. I have a hayne's manuel, but the diagram doesn't show the bearings seperating from the hub, nor does it say that you can or are supposed to remove the hub from the bearings. It also says you have to remove the axle. And do/should I get new lugs?
-I have never replace the rear bearing, but from the drawing of the manual, look like you have to seperate the rear axel from the companion flange (4 bolts), a large nut in the companion flange is now visable, loosen the nut, the axel shaft should come out, don't forget to get the new oil seal for the bearings.
