Snake
- 70
- Mar 26, 2003
I am tired of keep geting the god forsaken!!!! P1400 MDP fault
My car idles great and runs good except after 4500RPM it stalls a bit but in a few days my S-AFC will arrive and after tunnig it Iam sure that there will be no more hesitation at high RPM.
But back to the issue in hand is there a way to FOOL the PCM so that the god@#$%& MDP(manifold difereantial preasure sensor) wont triger the P1400 fault(check engine ligth).
And please dont tell me to youst ignore it beacuse the CEL can always warn you of other problems in the engine I youst wan to know if there is a way to make it go away for good!!
Youst so that you know my EGR system is working ok and EVAP system is also ok.My car is some what moded also.
Once again is there a way to FOOL the PCM into not trigering the P1400 fault???
Or if there is something else besides the EGR or EVAP systems that is trigering it??
Thanks in advance.
Thanks in advance.
