tranny/clutch problem
97turbodsm
105
Oct 31, 2002
Orange Park, Florida
for the last couple of days my transmission has been acting up. from a stop, it tends to pop first gear out. it was just every now and then but now it's pretty much all the time. today when coming home from work my clutch pedal stuck on the floor, popped first gear out and wouldn't allow me to go into anygear. my second gear has been a problem from time to time as weell just in the way of shift quality. i need some help w/ this. please. it's a problem and i need a diagnosis.
Sounds to me like a hydrolic problem. Check your fluid level in your master cylinder. Also check for leaks in that and the clutch slave cylinder. If that isn't the problem, it might be time for a transmission rebuild. A stuck clutch though sounds to me like crankwalk.
sorry it took so long to respond. the clutch had been making a slight popping noise when engaged ans disengaged, there was a slight scuffing or rubbing sound from the genaral area where the trans is.
slave cylinder definately shot, it's dripping hydraulic fluid. i looked at the pics at vfaq of the replacement process and it seems as though there is a lot more room to work. i do realize that it was a 1G. is there just *A LOT* less room on a 2G, or do i have another problem, like bent support beam? it looks as though that is what took the brunt of my bottoming out on a raised manhole cover. would that maybe have severely bent causing it to come extremely close to the trans? thanks.
Just about at any parts store...they can usually bend it for you and everything if you ask nicely...
Good luck!
Don't go and get it bent. The lower slave line is like 10-12 bucks from mitsu. Buy it prebent, that sheezy is very tricky and tempermental, I know, I've replaced it many of times. :thumb:
  • For sale 2g 2G DSM ECU
    Came off a 1997 GST M/T. Stock ECU
    • Stizzydrew
  • For sale 1g 90-91 Talon pass taillight.
    Pass taillight for 90-91 Talon. Good condition. No breaks or cracks. Will buff up nice...
  • For sale 2g 2G Manual Window Assemblies, Door Panels, & Hardware
    2G Manual Window Assemblies, Door Panels, & Hardware $250 + shipping and paypal feesYou must...
  • For sale 2g 2GB Talon Wing ( 3rd brake light included )
    2GB Talon Wing $90* pick up only in 08096 NJ * 3rd brake light includedYou must be...
  • For sale 2g 2GB Talon Front Bumper
    2GB Talon Front Bumper $200* pick up only in 08096 NJ * tear on the bottom side, picturedYou...
