sound227
- 51
- Sep 26, 2003
NORTHAMPTON,
Ok, I have a 1990 awd tsi with 114,000 on it. I pulled teh engine to regasket it roughly 3000 miles ago because it was getting smoky, figured it could use a once over. Well, anyways, I got it back together and everything was fine. This past week, I noticed that when I would start it, a puff of smoke would come from the exhaust, when the car was cold or hot. As the week went by, more and more smoke, and then it began to smoke really bad when I would come to a stop at idle. I spent today checking for leaks, checking compression, etc, and found nothing. The smoke is white, but I am not taking any coolant or any oil for that matter. Sometimes the smoke turns greyish/black, but it remains mostly white. I changed the pcv valve which was clogged and cleaned the TB and EGR as well. I am running a 255lph fuel pump on stock injectors, and have a hacked mas and uicp, thats all. I figured the smoke was due to a rich fuel reading, even though my A/F meter didnt really get too rich. When I pulled out the first injector, i found out that the cap was cracked. I ordered 550's like I should have a while ago today. I also replaced the stock reg with another stock reg just to make sure that didnt go out. It still smokes. My question is does this seem like a fuel combustion problem, which my friends and I have concluded. Did anyone have this problem, and if so, will the 550 and an adj regulator make the smoke go away. I do have a S-AFCII as well, but I dont really wanna hook it up until spring if I dont have too. If anyone can offer some help, that would be great. I have to use the car to commute to school and work everyday and I need this fixed asap. Thanks.
