loreak
- 533
- Mar 26, 2003
ok i tested and i have no spark, it just up and died
so today i checked my coilpack and its fine, and i tried a spare and didnt work, i checked my cam sensor and it seems to be fine, although in the manual it says to check the harness for everything not the actual sensor, which is kind of odd
so only things left are possible ecu went bad, crank angle sensor, and power transistor module right?
the ecu ill check tomorrow, but the other two are so hard to check because they are way down underneath the intake manifold, theres like no room to check
