SS Oil line leaks
RaysTsi
323
Nov 4, 2002
Charlotte, North Carolina
My SS Oil Line leaks where the flax section meets the threaded section?
How can I get it to stop? It fully tightened down. If you're wondering its connected at the Head and its the turbo feed line.
i broke my oil feed line yesterday, but i have a 1g head swap on the 2g i'm not sure what oil lines to buy from rre 1g or 2g i just got the car the same day, the motor has 350 miles on it new everything unfortunalty not new oil feed lines there is a line going from the head its a braided steel line then it connects to another smaller not braided line that goes in the turbo. it was leaking so i decided the connection was loose between the braided line and the little crap line i put a wrench on both side and tighented and little bit then the little line broke off right behind the nut. if you might know how i can fix this or where i can get a replacment oil feed line i would appreaite your help or anyone elses help alot becuease i just got the car and now i can't drive i'm a little upset.
