RavenX
- 659
- 5
- Sep 23, 2002
Daytona Beach,
Florida
i just recently installed a EvoIII turbo that i got from slowboyracing. Anyway the install went very smoothly and we got everything installed correctly. The problem that i have is that the turbo spools slow and it doesn't pull. I get full boost around 3,300rpm but the spool is slow and u don't get that instant feel of power. I rode in my friends car and he has a Big16G and the instant spool up he gets i don't. I have checked everything from coolant lines to oil lines and i have no boost leaks and i have no idea what could the problem be. We were thinking that maybe te wastegate actuator is staying a bit open? Then again my turbo has the 34mm flapper mod but i don't think that has anything to do with it. Although i must say i get no boost creep. Anyway you guys are my last hope i'll be taking off the turbo again to put on the EvoIII O2 housing...i hope someone here has experienced a problem like this. Also i have all the supporting mods just in case anyone will ask
Edit: As far as the car running the O2 voltages show a good .92v at Wot which i was told was ok. Also i noticed that my exhaust is vibrating a hell of a lot more that with the t25, possible exhaust leak? Also i noticed that i don't get the high pitched sound with the BOV(Greddy Type-S), its really quiet but still releases the "pshhht" sound but not as loud. Hope this helps
