eclipse90gsxt
- 438
- 1
- Feb 11, 2003
Rochester,
New York
Alright, I was doing 2nd 4rd and 4th gear pulls on the expressway tuning, I did about 3 of them total. The car is ready to run but then I hear a loud noise/vibration coming from the car. So I stop and look to see if my exhaust bolts or something had come undone, well nothing did. So I keep driving and it only usually makes the noise when I am off the gas and slowing down, or starting up or get into higher rpms. It also stops the noise when I push in the clutch. SO...I get home, my dad and I take the valve cover and head off....Fine. Now we think its the trans, I sounds like something from the trans.
Alirhgt, My dad maybe thinks the gear for the starter is hitting the flywheel, take starter out and it looks fine.
The car drives normal and goes in ever gear and boosts, but it makes a horrible noise. We are thinking a flywheel, clutch, flywheel bolt came undone or the Throwout Bearing is bad, we don't know, we are taking the trans out tonight to look and see. My question is are we thinking wrong and is there anything else it could be. Thanks for the help if you can. Driveshaft maybe? idk I need help, thanks.
Patrick
Patrick
I don't trust anybody anymore!
