Knock
Rogue_Ant
180
Dec 18, 2002
Denver, Colorado
Ok, I'm at the end of my stick here.
My car is getting knock no matter what I do. As soon as I get on it, it will shoot up to 30-43 counts.
93 Tsi AWD.
6bolt
no balance-shafts
Eagle rods
Ross pitsons, 9-1cr
Mildly ported head
reground cams
2G exhaust manifold
20G turbo unclipped
'indy' front mount
Hard intercooler piping
HKS SSQ
2G MAS
3" Turbo-Back, no cat, straight-through muffler
Walbro 255
Denso 660s
2g lifters
S-AFC
TMO datalogger
Urethane motor mounts.
ACT 2600 /w Street disk
90 Oil cooler
KYB adj coil-over
New Knock sensor
Ok, normal driving around I usually will get 1 count of knock every 30seconds or so. It will stay like this until ~7psi of boost. Then the knock starts to just shoot up. It doesn't matter if I'm running 15psi, 17, 21, ect. O2s are usually around .92, EGTs are ~1450f. I've ran the thing pig rich to quite lean without much change in knock.
Base timing is set @5btdc. By the end of the gear my timing will be pulled down somewhere between 2-8 degrees, depending on which gear. :mad:
I'm about ready to drive this thing off a cliff.
Any helpfull insight please :(
Rogue
Comon I know I'm not the only one who has had problems.
I've tried tightening the knock sensor, loosening it, moving it, putting a washer inbetween, ect.
Really could use some help.
Rogue
