Oil Seals
dbritt
178
Jun 9, 2003
Clemson, South Carolina
OK. Right now my cylinders are filled with mopar combustion chamber cleaner for the night and I'm going to finish that job tomorrow. I want to put fully synthetic in her, but everyone says that when you switch to fully synthetic you'll have to change all your seals. This leads to the question "what are all the seals?".
I can't find a post or a vfaq for the answer, so I turn to you. I looked in the service manual briefly and found the camshaft seals...but that's it. I read that the valve cover gasket is something that may need to be replaced. Also the oil cap. I need a full list of seals that should be changed when making the switch.
Thanks
