BlkTalonTsi
- Sep 30, 2002
Ok, I'm sick of working on this car. I have 2 problems...1. My timing belt makes a high pitch noise. Sounds like a big turbo winding up. THe pitch varies directly with the RPM. I took off the Timing belt cover and saw belt dust around the Oil Pump Gear (not a lot). It looks like the lip on the outer side of the gear is just rubbing on the edge of the Timing Belt. It also looks like the timing belt is just barely rubbing in the bottom of the timing belt cover. I can't move the cover enough to make it clear the bottom. Is the harmful? Is it going to shorten the life of my belt. Is there a fix?
2. I have a random miss at constant RPM and Decel... no matter what RPM. The car pulls strong when accelerating. I checked the Power transistor, the Ignition coils, the Camshaft Position sensor, Spark plugs, replaced the plug wires, I cleaned the injectors, fuel pressure is 40psi (I set it a little high), Replaced the TB Shaft seals and TB Gaskets. The A/F Gauge says I'm not running lean, So...I give up.
Any Help would be greatly appreciated.
