97dsmbishi
- 944
- Apr 9, 2002
Ok...here's the minor stuff that's killing me:
my power mirrors aren't working (they go down, but not L/R/or up..??
sunroof works fine, but when closing, it seems to slide of track & is a bi*** to close......leaks sometimes too(disconnected wire so no one can f*ck w/it). few minor bulb problems...which are easy to fix/replace (bulb, fuse...etc.) but how do i replace the bulb in the foglight? since i have no experience w/96's and below...how do i change the bulb?
also, seems my power doorlocks aren't working properly either....the driver side works fine, but when i try to unloc/lock the passenger side, from the driver side...nada.
HELP ME OUT PLEASE....
Thanks!
phil
Thanks!
phil
). Then there is a post in a hole that means the light needs to be pulled out and put in at an angle, well you'll see what I mean, it's not tough. Then there is a circular plug that can be unscrewed. Take it off and you will see the light. I believe the stock bulb is an H4, but your local parts store can help you out there. Plug in the new one, reassemble, and test.
