Extreme Dreams
- Aug 26, 2003
I have an Apexi Turbo Timer that reads the O2 volts. Problem I am having is that it stays .01 to .08 volts. The most it will ever got to is like .3 volts. It worked fine until I installed my 3" downpipe and exhaust. I checked all connections and everything and it was fine. The car generally runs ok, but not like expected on boost. (my friends car has the same setup as mine, except a small 16 compared to my evo, and pulls much much harder.) Is it possible the o2 sensor is bad and is causing the car to pull timming? I have alogger, but having problems with it connecting.
Thanks,
Jay
Thanks,
Jay
