theTuner
- 196
- Jun 24, 2003
Bay Area,
Ok so my frount mount started leaking so i took it off and put my sidemount back on... i turn boost down to 8 psi and lean out .. drive for a week or 2 like that, then i decided to up my boost to 12ish.. but everytime i hit aournd 10 psi of boost my car makes a big buck , even when i am soooo ####ing rich.. i logged it and im not knocking...it has to be fuel cut.
well anyway i was scared if ####ed something up so i took my car to prostreet in hayward and John from prostreet helped me. He tuned my low throttle then we after we were doing hi throttle and it wouold buck , so he checked out my engine , he though i had a blown HG, so i went home and changed my oil... no problems there... Now what should i do? any ideas?
my b16g is new so its not leaking.. i have magnacore wires on and NGK plugs which both have around 30kish on them? is it possible that a wire/plug went bad? how do i check wires? Today im going to check my plug gap to see if there are any major discrepencies. any info appriciated. Thx
