ArticNemesis
- 1,153
- 5
- Jan 3, 2003
Myrtle Beach,
South Carolina
Alright.. About a week ago, my car decides it is goign to start overheating.(not bad, but enough to make me panic) so, my water pump decided it's goign to start leaking.. No big deal. Changed the water pump, timing belt (and all the related accessories). Flushed the radiator just to make sure it's nice and clean.. the car still overheats, but only if i'm in stop and go traffic. It won't do it at idle, and it won't do it while driving constantly.. I can turn the heat on to make the temp go down, but it's summer time(you get the picture). I replaced the thermostat, and radiator cap. And it still overheats in stop and go traffic. The fan comes on eventually, (maybe not soon enough) so i'm going right now to install a switch to control both fans. I'm almost positive it's not the HG, short of a compression test, there is no white smoke, no coolant in oil, and there isn't any coolant loss. However, if i run the car with no radiator cap on, the coolant swells up and over the side of the radiator neck. Is this normal.? Any thoughts/opinions/suggestions Please!!!! thanks in advance.
-Brad
-Brad
