w1kk3d
- 178
- 6
- May 8, 2002
Milwaukee,
Wisconsin
(Applies to 2g's ...might apply to 1g's too?)
If you have those symptoms, like me, and have an S-AFC, did you CUT the airflow signal wire in HALF when you connected the pink (plug half) & orange wire (other half) ?
The instructions I used did NOT say to cut the wire in half, and after replacing plugs/wires/coilpack...I was about to get another ECU, when I read a little more about the s-afc install and noticed the vfaq version says to cut the wire, sure enough, my hesitation is GONE and no more CEL. I can't believe it was that easy, all due to someone's wrong instruction
I must have read about 20 threads here about this, so I hope this helps someone at least!
-jeff-
'96 TSi AWD A/T
-jeff-
'96 TSi AWD A/T
