2 part question
dunkyfried
152
Apr 12, 2003
Asheville, North Carolina
ok two questions, one simple and one I have no clue
1. On the stock oil gauge, what is it supposed to read at idle....mine reads below L, almost nothing. If I rev the engine then it goes normal. Is this right.
2. While at idle also I get the constant lifter tick, however, recently it has been accompanied by a on off droning noise.... Is this the water or oil pump or what on gods green earth is it?
Thanks guys
Want to get these taken care of b4 I throw my SAfc, 255lph, and 550s in
It's typical for the factory gauge to show almost no pressure at idle. A new sender may help.
1 grade higher-viscosity oil may eliminate your lifter ticking. It's an old car, clearances are greater.
I don't know about your droning, you may want to hit up a tool shop for an engine stethescope (or eBay for $7) to chase it down.
  • Wanted 1g Wanted - 91-94 1g Throttle Body or replacement shaft + plate
    Looking to replace a TB with a complete 91-94 or replace TB shaft + plate. Let me know!
    • athlete3344
  • For sale 1g 90 Oil Cooler
