TSi90Awd
- 73
- Aug 11, 2003
My valve cover just cracked for the second time in a month. The first time I overtorqued the bolts and it cracked. This time I had a torque wrench set at 4 lbs. and one corner on the indied pattern cracked. I was in the middle of putting permatex on the bolts. I have two questions: the engine was still hot when this happened, could that be why it cracked so easily? Also am I using the correct amount of torque? I was told to use 2-6 lbs. This is starting to be very irritating.
