I'd like to drive my new Eclipse but I need some help with the radiator fans
raceguy
Aug 4, 2002
Vermont
The radiator fans don't come on. I've eliminated the relay and fuse as the culprit, and I'm leaning on a bad heat sensor. Also, what is the pipe located in front of the radiator on a 91 GSX, because that is leaking. Thanks in advance.
If you turn on your A/C do the fans turn on? If so then your fans, wiring, relays.. ect are working. I would test both temp sensors at that point. If the fans do not turn on with the A/C on then you have an electrical or fan problem.
Make sure that your coolant is flowing and that your car is not overheating. If the coolant does not flow through the thermostat housing then the sensors will "think" that the engine is still cool and the fan will not come on. The pipe in the front of the rediator is an A/C pipe (not exactly sure what it does though)
Thanks for the replies guys. It turns out a wire had corroded somewhere between the relay and ECU. The pipe in front of the radiator is to cool the power steering fluid.
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted FIC Easytune
    Looking for a FIC Easytune box.
    • Stapl3
  • For sale FIC 1220 Injectors AEM 320lph fuel pump with rewire kit
    FIC 1220 Injectors AEM 320lph fuel pump with rewire kit. 450 shipped to the lower 48 states.You...
    • elocneas
  • For sale 4G63 Bastard 20g
    Bastard 20g turbo Like New
    • arodgst
  • For sale 2g 97 GSX part out
    Ex-wife's project car part-out. Will be updating the list over the next few weeks and adding...
    • Type1DSMr
