98TsiAWD
DSM Wiseman
- 2,861
- 8
- May 19, 2002
94 3000GT VR-4,
North Dakota
So I bought a 90 Tsi and am doing the timing belt on it.
I cant get the timing marks to line up at all. So I did it following the VFAQ leaving the intake cam 1/2 tooth up and the exhaust cam about 1 tooth down. (this is on the center marks). It said when I tensioned it that it would line up perfect, yeah right.
And amongst other problems, I dotn have the special tool to put on the tensioner pulley to properly set the tensioner. I cant use the battery bolt method because it is bent.
So I stuck a .156 drill bit between the tensioner arm and tensioner, then used a c-clip pliers that you screw in and out, stuck it between the tensioner arm and water pump, then pulled the allen wrench out of the tensioner (the c-clip pliers holds it in place tight at .156".
Then I slightly pried on the tensioner pully with a flathead just like the VFAQ says and tighted the center bolt on the pulley.
Took the c-clip pliers out, and pulled the drill bit out (had to use a pliers, is was tight), and now I cant get the drill bit back between the tensioner and tensioner arm so it is not properly set
I now tore it all back apart AGAIN, because the tension wasnt right, and the lines do not line up on the cams at all.
Im about to send this car to the junkyard.
I'm going to have to read that over 3 or 4 times. I'm in the middle of a water pump repair too. I don't have a tensioner either but u got me lost, I'm still not sure how i should get my tension correct. I'm still waiting for my belts so hopefully i have it all understood by then
