I just want to make sure this is the ECU before making a huge purchase....
Oreopride18
278
Jun 19, 2002
Well, the DSM died on the track yesterday. It was in top top shape (minus 2nd, as usual) and it would run fine one minute. But next thing you know I hear this insane clicking noise from the radio and the car dies. Start it up, head home at 50MPH while the car runs perfect....insane clicking noise and the car dies off.
Anywho, I busted open the ECU today and had a friend solder in three new capacitors. The board part by the "100" capacitor was eaten through from leakage of one of them and the smell of rotten eggs was in the board. Oh, and the ECU had been rebuilt by the previous owner and the warranty ran out last year. Anyway, put it back in the car...and it still dies to clicks.
Sucks bad. But before I go making the big purchase of a used 91-94 AWD Turbo ECU I want to make sure that it can be no other problems. The engine is perfectly fine. The car starts and may even run a mile fine. Then it dies by clicks.
As usual much help appreciated.
if your caps.have burnt through the board.i would replace it anyways.go to dsm trader and try to find one for cheap.
If you're unsure, then swap ECU's with another dsm first to make sure there isn't something else going wrong. I'm sure it's the ecu. The clicking sound is the fuel pump relay, which is just under the radio. It is switched off and on by the ecu. The circiut that switches it in the ecu is located under the leaky capacitors and is the first circuit to get eaten away by leaking capacitor acid.
  • For sale 2g 2g auto shift inhibitor with plug
    2g auto shift inhibitor with weather pack plug. Price is shipped USPS. Message 702-741-6987
    • 19Eclipse90
  • For sale '90 Laser turbo
    • GregPLT
    • pottersgst
  • For sale JFH REAR
    JFH Auto LSD REAR
    • pottersgst
