RuBiCaNT5X
- 1,244
- 3
- Sep 21, 2002
Buffalo,
New York
First off, I'm not sure about posting in this category but I am all out of options. I've attempted posting in others and have gotten no responses. If it is indeed not worth, by all means, move it. Ok, here is the scenario....
I first off have a 99 Auto GSX. This spring I've put a new intake, 3" exhaust and a MBC on... In a nutshell, when the car has been driven for more than 10 - 15 miles, in 4th gear (and with OD off) around 60 - 80 it will hesitate to accelerate when 15 - 20% throttle is applied. Going WOT the car will accelerate fine, but in the lower throttle region is where the problems arise. The one thing that I do notice that is different than before I've added the above mods is more heat in my engine bay (primarily due to the new exhaust). My coolant temps are around 200 degrees. I am leaning towards either some sort of ECU malfunction that isn't tripping the CEL or the TCU is having issues. If I am not mistaken, any problem with the TCU is not linked with the ECU, they just share sensor information. So if the TCU was malfunctioning, it would not trip the CEL, correct? I have yet to hook up an analog multimeter (no cash) to the OBD2 port but this weekend I will get results ASAP. I've replaced the TPS with a known good one thinking it was the problem, however that has no alleviated the issue. Are my theories about the ECU/TCU having issues reaching? Could the tranny be on it's way out the door? I really appreciate the help and appologize if this is not an Extreme Tuner worthy thread. Thanks!
Gimme your inputs whoever has subscribed to this thread...
