420a w/ a handful of strange (possibly related)issues
Lilni
73
Apr 4, 2005
St. Louis, Missouri
let me begin by saying that although this is an overwhelming amont of problems, my engine ran perfectly for 2 1/2 years (until a month or two ago). i know this is a lot to read but id really really apreciate anyones input.
Here are all the things my car is doing:
-knocking: it gets a quieter when the car warms up, but doesnt go away completely. gets a little better every once in a while, but its definetly getting worse over time. not a slow knock and its definetly not a tick. its not bad enough to the point where i wont drive my car anymore though...
the motor was rebuilt when i first got the car, but its given me over 30,000 miles without any problems
-vibration while im driving, only while in gear during acceleration or while im "engine braking" there are stronger vibrations that almost feel like a miss, those are pretty frequent... im thinking that a miss is a big part of my problem but i dont know what might be causing it. there has been one time where it popped, but it hasnt occured since then...
-a moderately loud whining noise coming from the cam gears/ top of timing cover: a while ago the idler bearings went bad, so i replaced them, converted to a mechanical tensioner, replaced the water pump, and changed the belt. Long story short, everything on the timing belt side is new and its still whining.
-High idle while coasting in neutral until the car stops completely: while the engine is warming up and im driving up the street, my idle stays around 2300 rpm after i take my car out of gear and coast to the stop sign in neutral. it usually goes down around 1500 rpm as the car slows down, but it doesnt go to where it should be (800) until i come to a full and complete stop for atleast 2 or 3 seconds. the rpms dont change depending on the clutch is engaged or not. there have also been one or two times where my idle began fluctuating and getting erratic as i coasted to a stoplight, but went back down to normal after i stopped for a second (it contnued til the car warmed up). for all of this, after the engine warms up completely, the revs drops down to 800rpms when i take it out of gear. this is by far the stangest issue, if anyone has any idea what this is i would really apreciate some input.
-a high pitched noise that starts around 3000 rpms, only happens when im accelerating really hard at WOT. this ones really strange because it sounds almost exactly like squealing brakes.
-sputtering when accelerating from low rpms. worse than it should be. the plug wires arent very old, but the coil may be. i put in some new plugs and correctly gapped them a couple days ago and the sputtering got a lot better, but still sounds kind of harsh
-engine doesnt start as easily as it used to
-gas mileage isnt as good as it used to be
-car runs a couple of degrees warmer than it used to
-i pulled my new plugs after they had been in there for about a week and one of them was white. it matches the "too hot" plug in the haynes manual, but that doesnt tell me what the problem might be... i also have to use a sleeve for this plug because the hole had been stripped out a long time ago and tapped. i have a feeling this cylinder may be where my problem is. the knocking is either coming from this cylinder or the or #3
i dont know if its ignition or fuel or predetonation or what. one theory i have is that my ecu is picking up the knock and retarding the ignition timing but i dont think the knock is bad enough..
it may sound like i just need a new car, but its not all bad. it works just fine, but everything feels like its off and its really really bothering me. if anyone has had any similar problems in any sort of combination and fixed them i would really appreciate the insight. even if you have a theory, id appreciate the help
^^^^ The knocking you describe could\will cause just about every other issue you named.
its knocking in the block for sure. im almost positive it was one of my pistons kissing a valve, but somehow over the past week the knock has gotten a lot better. why this is, i dont know, maybe some carbon got blown out and i got some clearance back. a lot of the other symptoms are doing a lot better too; the vibration has gotten a lot better, the sputterings gotten better and it doesnt even barely knock when i start it up. go figure... im still going to be investigating the whining coming from inside the tb cover this weekend. ive replaced all the damn idler bearings, the water pump and oil pump so i know that all the bearings are good, but this leads to the ultimate answer that i probably did something wrong. oh well, im happy right now as long as that motherf***ing knock doesnt come back :rocks:
