atlguyinbama
- 69
- Feb 21, 2006
Madison,
Alabama
Ok guys I'm stumped.
Here is a quick mod list to begin with.
Built Motor
-Wiseco 9:1 pistons (.040 over)
-Stock Rods
-ARP Hardware throughout
-MLS head gasket
-Balance Shafts removed
-Brian Crower 272's
-Stock Head and Intake Manifold.
Turbo & Exhaust
-Evo III 16g
-Bullseye Power SS exhaust housing w/38mm flapper
-Evo III Exhaust Manifold and O2 Housing
-3" Turbo-back
-Greddy Type-S
-ETS Street/Strip FMIC
-Dejon Tool MBC
Fuel
-Aeromotive AFPR set at 42lbs
-550's
-S-AFC II
Ok, I just got through with the break in of the engine and clutch, and was out trying to do some 3rd gear pulls to do some tuning with the logger and AFC. When I rolled into it, boost spiked to 25-27 psi just as boost came on, and fell back all the way to 12-13psi the rest of the way up to redline. It seems like whatever I did to the MBC (which is tee-d into the BOV line as there are no other nipples), it changed absolutely nothing with either the spike or the settled boost.
Now, I did have to play with the stock WG actuator some to get it to work with the Bullseye hotside (had to shim it out to get the flapper to get even close to closed). The flapper is not closed all the way when not pressurized. Yet I could not see this doing anything but probably cause some slow spool up times. And it does not seem to be binding at any point.
I have studied a lot of posts on here, but none are anywhere near a 15psi spike. This is a new one on me, as Ive never seen anything like it in my 5 years of DSMing. Please Help!!!
Built Motor
-Stock Rods
-MLS head gasket
-Brian Crower 272's
Turbo & Exhaust
-Evo III 16g
-3" Turbo-back
-Greddy Type-S
-Dejon Tool MBC
Fuel
-550's
-S-AFC II
problem solved?
