Strange door lock problem.
JMiller
684
Jun 30, 2007
Irmo, South Carolina
Ok so my power locks started acting up awhile ago. for some reason with the door closed and locked the thing would keep making the locking sound, and drained my battery when i let it sit for 2 weeks. I took out the fuse for door lock and security to keep it from draining the battery. So today i decided to put the fuse back in and it instantly locked the doors, but when i hit unlock it did nothing. So i took out the fuse put the key in the on position put the fuse back in and nothing.(it only locked the doors when i put the fuse in with the key out) So when i went get something to pull the fuse back out i closed the door, and when i came back it had locked itself with the key in on position(was listening to radio). Luckily i had my sunroof open and my brother was able to unlock it for me. So does anyone know what might be the problem.( Door wont unlock at all.):dsm:sorry for length
Did you check the lock actuators in the doors.. specifically to see if maybe one of the electrical wires going to it is stripped somewhere and touching metal that may cause a short.
