95 Talon will not start. Help!!!!
Emmisky15
Jan 30, 2008
Fredonia, Pennsylvania
I really hope someone out there can help me with my problem. I am going to lose my mind trying to figure out what the problem is. I have 95 Eagle Talon, it just quit running about 3 weeks ago. I have replaced the starter, neutral safety switch, plugs, wires, and the battery is good. Does anyone have an idea?? Thanks in advance!
ok well we need some more info. what does the car do when its "not starting"? can you hear the starter click? have you checked like spark or anything? does the car run then die....some more info would be good!
very true more info would help the guys out on here a great deal. Im sure everyone can help you but we need to know some more info so we can figure out your problem. Does it turn over? have you done a compression test? what happens when you turn the key
I see you have a N/T w/ Turbo, Fill out your profile so we can see what you are running it helps us figure out what could be the problem.
-How much boost are you running?
-What is your fuel set-up?
-Have you checked for spark? Fuel?
-Did it make any sounds when it stopped running?
-What did your plugs look like when you pulled them?
-What does it do when you turn the key?
You posted the most vague description of the problem as you possibly could have. If you can answer these questions and possibly even get a video I bet someone on here will be able to tell you right away.
Good luck
  • For sale 2g 2G DSM ECU
    Came off a 1997 GST M/T. Stock ECU
    • Stizzydrew
  • For sale 1g 90-91 Talon pass taillight.
    Pass taillight for 90-91 Talon. Good condition. No breaks or cracks. Will buff up nice...
  • For sale 2g 2G Manual Window Assemblies, Door Panels, & Hardware
    2G Manual Window Assemblies, Door Panels, & Hardware $250 + shipping and paypal feesYou must...
  • For sale 2g 2GB Talon Wing ( 3rd brake light included )
    2GB Talon Wing $90* pick up only in 08096 NJ * 3rd brake light includedYou must be...
  • For sale 2g 2GB Talon Front Bumper
    2GB Talon Front Bumper $200* pick up only in 08096 NJ * tear on the bottom side, picturedYou...
