hydrastas
- 151
- May 29, 2008
tonganoxie,
Kansas
i just installed a boost gauge finally, i've yet to figure out my weird idle problem but at idle the vac on my gauge bounces so rapid between -6 to -10 psi that it's blurry? after reving it up and letting off it will read -18ish like normal though... on the positive side i went WOT and it said my boost was only 5? should i check for boost leaks before i go and try to set my mbc to 15 psi on this gauge?
. i plugged in my vacuum pump where the boost gauge is and it has the exact reading so im pretty confident the gauge is working. would a boost leak be the cause if im only getting 5 psi?
