bent valves??
eagletalon_92
Jun 21, 2008
Batavia, New York
So my husband was driving my car when it died. Come to find out after taking off the valve cover and the timing cover we broke 8 rockers and the balance shaft belt broke and slipped time. What are the chances that I also have bent valve? I really don't want to pull the head if i don't have to. thanks for any help
Sorry but more than likely your pistons have dents in them and your valves are all bent. Pull the head, and check your pistons... If your rocker arms are as loose or broken as you say they are then more then likely your valves are bent.
I doubt you broke a rocker. More than likely they just popped off which is what happens when pistons meet valves. If the engine is still able to be cranked you can do a compression test to be sure.
ive seen a broken rocker, about 12 of them pulled out of a 91 N/t with a busted belt and bent valves. the rollers were busted off of the rockers
thats what i belive happened to mine every valve is bent and the pistsons have big indents in them. it sucks.
    • eclipsemf
