DSMLink + DSBC?
RadDsm
1,679
24
Apr 28, 2008
Eugene, Oregon
Can you save 2 different tunes on DSMLink, to use a dual stage boost controller? I figured you could, but couldnt find any threads with the same question. Thanks guys
You can save multiple tunes for DSMlink. It will take you a minute or so to load a new tune though. If you tune for a certain psi, go to ECU/Logfile > Load/Save/Type > Save to disk... and that will save the ECU settings you just programmed. Then tune for the other psi and do the same thing. Then you can name them according to their psi and you'll know the difference. And when you want to change your tune, go to ECU/Logfile > Load/Save/Type > Load from disk... and then select the tune. Then go though all the options under the ECU/Logfile drop-down menu and open each one and click Copy To ECU to make sure the new settings are saved.
Thanks for the info. That is exactly what I was looking for.
With a dsbc you can just flip the switch and not load a tune. What you will have to do is tune the car for the high psi you will be running. When you do that you are tuning all the wot airflow sliders. So when you lower boost it will still be tuned since you already tuned all the airflow sliders.
Edit: Figuured i should menntiona couple things that I leftout.
1. The tunneneeds to bedone ona specific fuel youwill use for both amountsof boost. Don't tuneit on race gas andhigh boostthen put pump in and switchto low boost.
2. This won't give you the most power on low boost since the timing sliders will most likely be lower than you could get.
