Oil pressure !!!
92-eagle-talon
43
Apr 17, 2008
edmond, Oklahoma
Oil Pressure is perfect at startup and cold idle.
When engine is warm the oil pressure drops below the stock L line
I'm using castrol gtx 10w 30 and mobil oil filter
If i'm driving and let off the gas and press the clutch to stop the engine dies.
When I check the oil the dipstick indicates that it is at the correct level.
The oil on the dipstick has a slight smell of gas and is a greyish color.
I think that 1 or more of the injector seals is leaking.
What could be the cause of the low oil pressure ?
Is it safe to drive the car like this ?
please help !
First thing first, put a manual oil preasur guage on there and check what you are really dealing with. If it is still low when warm you probably have one of 2 problems worn oil pump or bearings going out. Does it knock? If so time for a rebuild. If not replace the pump and check it agian.
I changed the oil and now the oil pressure guage stays between the L and the first quarter mark. Is this where it should be ? The engine does not knock, However there is a slight rattling or pinging sound sometimes when accelerating uphill. How loud are the injectors on the 4g63 ?
DID you ever figure this out... I'm having the same issues ... mechanic told me CTS, pointed at the a/c switch though :( so that was already a red flag... only happens after all warmed up.... just wants to die ...and will, then takes a while to start back up... otherwise has been running really well. some hesitation on acceleration in lower rams . plus terrrrrrrible gas milage , so i still want to change out the 02 sensor or sensors and the cts
    • sanmantsi72
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
  • Wanted 4G63 800cc injectors
    • DSM_Thorpe
