92 talon no start need help ***RESOLVED***
dazzellerr
200
Dec 15, 2007
boise, Idaho
searched, found some related stuff with similar problems, but i know the motor is not toast LOL.
92 tsi manual transmission. car was in a slight wreck, was running apon impact.
bought it for a swap.
checked fuel with starting fluid, dont hear the fuel pump at all. have spark, timing is good, belt is good, plugs are good, cranks fine with jump box and battery.
compression is 150+ all across, not over 160. gaps on plugs are within spec. does have a broken radiator, might be the water sensor, but not sure on that one. should not make a difference i hope.
trying to hear it run before i yank it out and swap it into my project car so any help will be appreciated!
dazz
thanks for the help fella's, seems as though i didnt put enough starting fluid in there, got some help doing it and she fired up on starting fluid. no fuel pump though, probably a relay or fuse, injectors are getting pulse though.
engine sounds great too. time to tear it out LOL.
  • Wanted 2g ABS - Left side harness brackets
    Looking for the metal brackets for left side ABS wiring harness. Sensors not needed
    • Justin DuBois
  • For sale 2g 2GB CAS Assembly ( Complete )
    2GB CAS Assembly ( Complete ) $85 + shipping and paypal feesYou must be registered to see element.
  • For sale 2g 2G Clock Spring, Wiper Stalk, Turn Signal Stalk
    2G Clock Spring, Wiper Stalk, Turn Signal Stalk $35 + shipping and paypal fees* removed from...
  • For sale 4G63 2G Cylinder Head
    2G Cylinder Head $250 + shipping and paypal feesYou must be registered to see element.You must...
  • Free 4G63 1G /2G ECU Connector
    Came with a parts car, 1GA Talon with a 2G ECU. Some wires look cut and spliced. I have no use...
    • Badge023
