Car won't start
davidgt97
97
Jul 13, 2007
eastview, Kentucky
My car has not ran very well since I bought it. It has always had a hesitation or miss especially under boost. After many new parts including a new Kar King long block, new MHI evo 16g, header, exhaust, o2 housing, 560 injectors, walbro 255, etc.. I'm still in no better shape. Last week I tried tweeking w/ the car some more and while driving the hesitation seemed to get worse. I pulled the car in the garage and left it set. Today I went out to move the car out of the garage to do a brake job on my wife's car and it wouldn't start. I cranked for quite a while w/ no results. I have never been able to hear the fuel pump while trying to start the car but I thought I'd try hot wiring the fuel pump anyway. I hot wired the pump while I had my wife crank for about 10 sec w/ no results. Then I did a comp test just for the fun of it. I got about 155 across all 4. Then I pulled every plug and grounded it to a valve cover bolt to ensure every plug was firing and they were. Now what?
Today I went out and did something I know I shouldn't do but oh well. I pulled the throttle body hose and sprayed a little starting fluid in. The car fired right up and I quickly tried to give it some gas but it only ran for about 3 sec. and then it died and refused to start back. I'm guessing this means I'm getting no fuel. Any ideas?
Maybe your pump was failing. Causing you to run lean and get some timing pulled. Sounds like a bad pump. Do you have a logging device?
umm.. does jumping a failed component make it work?
you could've seen if the pump had power with a 2$ DVOM.
Or you should've T'd in a FP guage to see if you are getting pressure.
I pulled the line from the fuel rail and put it in a glass jar. I had my wife crank the motor for about 10 sec........ nothing. I guess next I'll check to see the pump is getting juice. I think I might be a little pissed if my brand new walbro 255 has already died, but as I mentioned before I have hot wired it and could hear it pump. I just thought of something as I was typing. I wonder if my fuel guage isn't working and my dumb ass is out of gas.
Well it's official, I'm the king jackass. My car runs better w/ gas and my fuel guage isn't working. Thanks guys.
