gma0408
- 75
- 1
- Aug 18, 2006
Waukegan,
Illinois
My 2g GSX WILL NOT START!
Mods:
Fuel Mods
255 walbro
Full Throttle AFPR
1000cc RC injectors
New Filter
Engine Mods
6 Bolt ( perfect compression...as of last day it was running)
<15,000 miles on longblock
Wiesco Pistons
Scat Rods
264/272 Cams
Magnus IM/ 1G TB (BISS out)
Maf Translator
GM Mas
Tuning
Dsmlink
AEM Wideband
I guess I should start from the beginning. About a year ago I had the timing belt changed. Then (related or not) less than a 1000 miles later the car started missing. WHY? I HAVE NO IDEA?
-Dsmlink showed nothing wrong (and no cel)
-Pressure at rail is good
-I put in new spark plugs (gapped proberly)
-Known working Coil
-Transistor
-Spark plug wires
-Swapped out the translator/Gm mas for a 2g
-Changed CAS
-Took out Injectors and tried swapping in an Oem ecu
-Swapped Engine Harness'.
-All relays in center console including MPI
I checked the timing and I saw that it has a broken bolt threaded into the hole for the tensioner...which means that maybe there wasn't enough tension and the timing skipped! ....NOPE! Redid the timing and used the Miller tool to correctly tension the belt. Nothing.
I pulled the plugs out and had someone start the engine...Its like a laser show! They all work.
The plugs are covered in gasoline! and at the rail, the fuel pressure is correct.
WHAT IS IT? WHAT COULD I POSSIBLE CHANGE OUT! Really though.
Mods:
Fuel Mods
255 walbro
Full Throttle AFPR
1000cc RC injectors
New Filter
Engine Mods
Wiesco Pistons
Scat Rods
264/272 Cams
Maf Translator
GM Mas
Tuning
Dsmlink
AEM Wideband
-Known working Coil
-Transistor
-Spark plug wires
-Changed CAS
