Stapl3
DSM Wiseman
- 2,261
- 981
- Oct 27, 2004
MI,
Michigan
Car is a 1992 Talon TSi AWD 6/4 5speed.
Anytime the HVAC fan is blowing, the lights automatically come on. As if I were to turn my lights on (not headlights, one click before that). Also, if there is no key in the ignition and the HVAC fan is set to any speed, the HVAC will begin to blow if I turn the lights on. I am told this is not normal behavior.
Both front turn signals light up when the lights are on, but they do not flash when I use my indicator. Only the rear lights work for the turn signal. They flash twice as fast as normal. There's a few plugs behind the headlights that seem to go to nothing. They are all female.
The interior lights don't work. I changed the dome bulbs, but no dice. Is there a fuse? The interior fuse box cover is missing.
Recently, when I tap my brakes, the power to the vehicle will nearly cutout for about half a second. Same goes for when I change my headlights from normal to bright and vise-versa. If I stop the car and the headlights are on, they will cutout for about half a second then come back on until I turn them off. This is a new problem, I'm hoping it's a loose battery connection or something.
Thanks in advance.
Thanks in advance.
