Prodigyman
- 215
- Jun 22, 2004
Toronto,
So I got a third DSM (215 000KM/128 000 Miles 95 TSI AWD with nice snows) for winter/spring beater while my GSX is getting ready in the shop(Fully built 6Bolt stroker, FP3065 etc etc...). So this DSM being DSM I fixed tons of things on it using stock spare parts off the GSX and now I got to the boost leak test...
Car as 1G BOV and metal UICP (to the last bend and then its stock) rest is stock rubber. Turbo to TB no leaks at all (changed TB(from GSX) and both gaskets too). Now I hooked up my tester to the TB and pushed about 15 PSI on 3GL compressor through it. Boost gauge registered about 9 PSI and died off to 0 in about 4-7 seconds, air sound was coming from intake runners area (sounds like mani gasket but I doubt it)
My question is don't you have to crank the engine certain way so air doesn't leak through the head back to exhaust, if so what is the proper way of doing it so I can pressurize the intake manifold properly?
Car runs retarded rich (even with new 6'sNKG plugs, NKG wires, new Denso O2, new(Front AND rear) new stock Rad n coolant, GSX working TB+new gaskets , 60k T25 and all gaskets, Fresh 10W30 Mobile 1 Synthetic with Lucas + OEM Mitsu filter, new DeJon intake and K&N Filter and fixed ALL exhaust leaks). Mileage is about 200 KM a tank (~124 miles) on Sunoco 94. So I tired evething and I am LOST, why is this DSM consuming retarded amount of gas, I mean my GSX when it had HUGE boost leaks and leaky injector gave me 230 miles a tank and i was not babying it ether...
Took off OLD MBC (Spring type) and directly connected from Turbo to WG so its solid 12 PSI with no creep @ ~ 2800 RPM, Idle VAC 11-16 in/hg.
