fubar_mdw
- 100
- Dec 6, 2007
hampton,
Virginia
well i fixed the problem i had with the knock in my car
http://www.dsmtuners.com/forums/newbie-forum/283099-some-knocking-head.html
that was the forum
it was i believe a bad leak from the intake manifold gasket.
now i have very low oil pressure (stock oil pressure gauge)
the lifters tick very slightly when the motor is cold,
and my boost gauge (greddy) sits on -15 on the guage at idle and goes even more
negative when i give it gas,
i went through all the vaccum lines (emissions deleted)
and egr blocked off.
cant find any leaks what so ever and there is no oil leaks either
the timing is dead on and the base timing is set at back 5tdc.
that was the forum
