sd_ff22
- 547
- 1
- Jul 26, 2004
Zushi, Japan,
Asia
Hey everyone.
yes, I've searched.
Ok, so I am installing my RRE stainless brake lines and I CAN NOT get the flare nuts off the rear. I have PB blastered the Hell out of the fittings and yes, I am useing a flare wrench.
The nuts are rounding off and the fitting is so tight on there that it is causeing the flare wrench to stretch open!!
Any Ideas or tricks?
Yes, I tried the vice grips on the rear passanger side and did tear it up a bit, but I filed it back to 10mm on each side to use the flare wrench. Still no go!
-Dan
yes, I've searched.
-Dan
Got the brake line loose for me. This should work for you
