Wizeman76
- 47
- 15
- Aug 29, 2005
Wales, United Kingdom,
Europe
Ok, I turn the car on, it runs and drives great. I go to turn it off, take out the key, and the engine is still running. All the interior electronics - radio, fans, wipers stop working, but the cluster lights and tach are all still on with the engine still running. You can rev it up, drive it all you like but it wont turn off. Even if you stall it, the cluster lights are stll on, killing the battery.
I have no turbo timer installed, I've tried wiggling the key iginition switch - even unplugging it with no effect. The only way I've managed to turn it off is either by unplugging the ecu, unplugging the small metal box next to the ecu, pulling the MPI fuse in the engine bay. I tried pulling the IGN fuse but it had no effect.
I've tried 3 different working ecu's, all do the same thing. I even changed that little metal box next to the ecu with one from a working car. The engine will contiue to run untill the fuel runs out. I really can't figure it out. Can anyone help me? I'm considering wiring a kill switch using that MPI fuse but I'd rather have the car working correctly.
