Meklo_4G63t
- 315
- Dec 2, 2007
North Charleston,
South Carolina
Alright fella yesterday we had did a radiator changeout on my 91GST that i had for like a month and first turbo car from leaving nissans. Well we pulled the intake hose side of the turbo out yesterday and I notice a little oil. then I went to feel the blades and the shaft to see if the turbo was going bad and I found nothing. Well got the radiator in and changed the air filter and the car was pulling alot better but we did a bigger investigation and swaped the b.o.v. with a buddy of mine that bleeds to the atmosphere and ran it to were the turbo would spool up around 12psi. after 30 mins we got a film of oil coming aroud the bov. To me I was thinking a seal in the turbo is about to go bad but on cars like these like when u have a leaky valve seal do they do that. some advise from anybody on there opinion with this problem i would thank you because to see were the money would go
. They feed hot oil vapor back into the intake tract which increases the intake temp. and hence tendency to knock. In addition they coat your piping and intercooler with oil inside.
, i know you can replace and rebuild turbo. I prefer to upgrade my turbo if i am going to do anything, not rebuild a crap t25
