BlackTSIjunker
- Nov 12, 2007
Philadelphia,
Pennsylvania
Hi I'm new to the eagle scene... I just bought a 91 talon turbo that doesn't start. I have eliminated the problem down to no spark.. I have already replaced the Coil and power transistor thing with known good ones.. still no spark.. the previous owner stated that the only thing he tried was replacing the ECU... when he did he said it ran for about a minute then shut off... i am going to try replacing the cam sensor next... I just wanted to know if any1 had encountered a wiring problem which may short out the ECU after just a few minutes of being installed.. also I am getting fuel to the fuel rail but I am unsure if the injectors are spraying but there is deffinetly no spark. Any help would be appreciated Thankyou.
