Clay
- 119
- 1
- Jan 2, 2003
626,
California
Symptoms
UPDATE: Initially, the CEL did not light up in the dash gauge. I found the P1300 CEL through pocketlogger. The next step continues here:http://www.dsmtuners.com/forums/showthread.php?t=272400
- Low idle ( 200 + rpms ) no stalling issues
- Can't rev past 2,200 rpms in neutral or in gear, even on WOT.
- Hesitates like fuel cut when I throttle past 2,200 rpms
- Both radiator fans turn on intermittently
- No boost leaks
I thought I did everything to fix this problem.
