mannyc
- Aug 24, 2007
Portland,
Oregon
i have a 95 talon ESI that i just put a new head on it. i tuck it to the machine shop and they said it was good. now when the car starts there is a clicking noise. it gets even worse on higher RPM. if you disconnect a spark plug the noise diminishes. i have removed the valve cover and i can not see any thing that might be making the noise. i have also put a new coil pack and the nose is still there. the ideal is also high and not steady goes from 1500 to 2000 RPM. can you help me for both problems. Thank you
