2g Idle and Stutterbox problem.
Boost95
403
Oct 21, 2004
Wilkes Barre, Pennsylvania
I'm having some trouble with a 97 GSX. Built motor, 20g and supporting mods.
I have 2 problems. One problem is with the idle after putting the clutch in or putting it in neutral. The other problem is the stutter box no longer works when the clutch is down.
IDLE problem: When I come to a stop and push the clutch in the wideband reads very lean and slowly comes back to 14.7 or so.
Stutterbox: When I push the clutch in and push the gas it goes direclt to the rev limit. I've tried all the settings and none of them work.
This problems did not start at the same time. So there's no relation
Thanks for any help.
Mike
Mike
What's your build, setup, mods... etc. etc. You know the drill!
Boost95, if you have Dsmlink(which I guess you do), check the clutch wire to make sure it is connected properly or hasn't came loose or got cut for whatever reason. See if you can log the isc motor and recheck your anti/clutch cut settings.
