Fuel Pump Help
1stGenTSi
323
Apr 8, 2005
Austin, Texas
My car will crank about 3 times and then make a loud grinding noise. I have tested the starter and it is good and my fidanza flywheel is only about a year old. My car made this same noise and wouldn't start a week ago so I pulled my fuel pump out checked all the wires and reinstalled. The car started right up and would never make the grinding noise.
Now I have determined the fuel pump isn't coming on again. I put a jumper wire from the Pos battery terminal to the fuel pump test connector and it just burns up the wire. I can put power directly to the fuel pump and get it to come on. Its a brand new walbro. Thanks for any help. -John
Edit: If my fuel pump relay is bad would the test connector not power the fuel pump?
Ok, so I pulled the fuel pump back out, bench tested it, put it back in and the car fired right up and the test connector now works. I didn't do anything but take it out and put it back in. Now when I hit the gas it has about a 1 second delay before the engine revs. Man this thing is driving me crazy. I just put $1500 worth of parts into this thing and it's left the garage twice in the last 3 months. I assume I have a short somewhere which caused the test connector to pull way too much current, burning the wire up, but I don't understand how removing and reinstalling the fuel pump has gotten it to start twice now. I don't want to drive it because I know its gonna leave me on the side of the road for the third time. Hopefully I can figure out the fuel pump issue but I need some help with the throttle issue. Like I said it take about a second after stepping on the gas before the engine revs. I've seen this before on cars with electronic throttles but it's never happened to mine before. Sorry about the long posts. Please help. -John
