clutch problem
JKL
38
Jan 23, 2006
Phila, Pennsylvania
I've done all the searching I could do. I have read and tried the suggested advices of previous posters for similar problem. The problem is the clutch in my 1990 talon tsi doesn't seem to disengage until it's just off the floor. The amount of range I have is very little. I have stepped the stock flywheel for the ACT2100. I have adjusted the clutch pedal but seemed to only help the problem for a brief moment before the range decreased again. I have checked for leaks. The slave seems to be ok. no leak when uncovering the boot. As for the master cylinder, there seems to be a small leak b/c dark fluid shows around the boot on the master cylinder that has the adjustment bolt through it. I check the clutch movement and the slave seems to have the proper movement to the clutch fork. I have a ACT throwout bearing installed.
Did you check the clutch pedal assembly for play? Even the smallest amount can cause problems. A good bleed would be easy and may get any air out if present.
  • For sale 1g 90 Oil Cooler
    • kyler021
