power steering line question (searched)
robbo185
201
Sep 4, 2005
chicago, Illinois
I have a leak at the two rubber parts that are circled in the attached picture (not sure if its a 2g or 1g diagram but its the same spot in my car 92 gsx) After searching i found no definite answer. Do i have to replace that whole metal line that its connected to or is there something i can do to just splice into it or something. Both of the spots are leaking at a constant drip. Any help is appreciated!
48826 will need to be replaced.
48862 can be removed its a power steering cooler, which you don't need unless you rally race, most dsmers have removed this as well as myself. Just connect 48827c & d together by removing those and getting a rubber hose from a parts store, coolant hose should work fine. Just make sure theres no kinks in it, and its a tight fit.
thanks for the help, i forgot to mention the line in the upper right that is circled is not broke. I found the diagram on another thread and thats the one the other guy broke. Im gonna head up to autozone tomorrow and take the advice of redeclipse. Thanks again!
